UMI lower a-arms ball joint question
I over greased the ball joint and there is grease coming out at the base of the ball joint like this
![](http://i14.photobucket.com/albums/a345/some_punk/IMG_0329.jpg)
![](http://i14.photobucket.com/albums/a345/some_punk/IMG_0328.jpg)
Is it okay or should I replace it? When i Squeeze it more grease comes out.
The grease is just coming out around the boot... you should wait until the A-Arm is installed before greasing... this way the boot is sealed better. You should put some pressure on the boot and reseal it. Once installed you can add some more grease but don't over grease because you don't want to blow the boot out.
