So what should I do??
Koni SA fronts are $299 each, while not cheap it's a far cry from $438 each (and I don't even know where that number came from anyway).
If you have questions, I stronly suggest you use the phone and call me. Clearly there is some confusion on your part.
What should I have done? Let you assume what you saw (and intimated you saw on my site) was correct and forget about it? That's not my style.
I can't answer what you saw, because I don't know where you were looking.
Go with strano springs and koni shocks and buy from Sam. From reading all your posts, this is basically my recommendation in a nutshell.
EDIT: Your from PE I just noticed. I definitely recommend Sam then. You'll get your stuff really fast. Sam's from PE. Buying stuff from him over time works out pretty well too because you'll develop good relations and I think that's always good to have.
I can't make recommendations without talking to you directly. Based on a conversation, I can make some recommendations to you, and we can put together parts that suit your needs.
Regardless, shocks first, period. Wish I had.
