C5 Brake Conversion Abutment Question
The only issue I've run across doing this conversion is the C5 pad would rub the F-Car abutment bracket where it arcs next to the rotor hat. The differences in the arc between the 12" F-Car rotor and the 13" C5 rotor is just enough for the C5 pad to just touch the abutment bracket.
I also seem to recall the tolerance between the F-Car abutment bracket and the thicker C5 rotor could be an issue, depending upon how much run-out the rotor has.
So there are some clearance issues when homogenizing the 2 platform's brake packages.
But, I have red Z06 calipers on my otherwise completely stock F-Car front brakes. The C5 caliper is the only change. This is my second season on them without an issue. The reason for the change was to eliminate pad taper due to caliper spread.
You can almost make out the red caliper in this shot ...
![](http://www.lawmotorsports.com/Pics/Mitch/Web/Hallett_06_08_30.jpg)
The F-body abutment bracket mounts to the spindle with 12mm bolts, the C5 attaches with 14mm bolts.
I have C5 calipers, C5 rotors, F-Car abutments brackets and pads and from my experience this isn't a good combo. My pad wear is not normal and I get fade I think caused by this uneven pad contact.
I am planning to purchase C5 abutments, a pair is under $90.
Just my experience,
Brian
Just my experience,
Brian
Just my experience,
Brian
Just my experience,
Brian
The caliper is a direct bolt-on, though, using the F-car abutment bracket.
