Help me find brake fitting.
I need a couple of fittings i cant find anywhere.
I need
Male -4an to male 12mm x1.5 bubble flare
Male -4an to Female 12mm x 1.5 bubble flare.
Anyone have any ideas??
I've been through
Earls, Russell , aeroquip
Just thought i'd check here.
TIA
Josh
I need
I've been through
TIA
Josh
tap into the line coming right off the master cylinder for a line lock for a friends C5.
he found someone that sells a kit but doesnt want to spend 225 bucks, for something we can get all the parts except those adapters for 50 bucks.
I'm sure we have something you can use. Give me a call on Monday to discuss.
Stay away from adding braided lines to your braking system (sounds like this is what you're trying to do).
Replacing a rubber line with a braided line can be beneficial.
Adding a braided line in place of hard line can add a more spongy brake feeling as you're increasing the likelihood of hose expansion under pressure. This leads to longer pedal throw and less precise braking.
Talk to you on Monday.
