setting adjustable front a-arms
Old Feb 6, 2009 | 12:27 AM
ls1foxcoupe's Avatar
Default setting adjustable front a-arms
What is the best method for initally setting new upper and lower a-arms on the front.
Old Feb 6, 2009 | 07:11 AM
UMI Sales's Avatar
Thumbs up A arm question
Hello
Are they after market arms? And if so who makes them.
Thanks Brad
Old Feb 6, 2009 | 07:23 AM
BassProCamaro97's Avatar
I'd like to know also.
~Jim~
Old Feb 6, 2009 | 08:33 AM
Biggin'89's Avatar
yep. I have some UMI's and i was thinking the same thing. also maybe a starting place for my qa1's as well.
thanks
kyler
Old Feb 6, 2009 | 09:46 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Originally Posted by UMI Sales
Hello
Depends on what you want. You could use the factory arms to set the lengths good enough to get it to an alignment shop. Or you could set up with plum bobs and masking tape on a level surface and get everything pretty damn close. My suggestion is getting it close with the stock stuff and get it to someone reputable to get everything on point.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Feb 6, 2009 | 10:11 AM
UMI Sales's Avatar
Originally Posted by BMR Sales2
Hey Jay seeing how you always like to quote on UMI's post! When we try to help people. What is that thing even doing? is it crapping out the mouth? Hopefully that's not what your doing seeing how a lot fly's this way......lol . The reason why I was asking if they are aftermarket A arms is UMI Performance presets there's to stock settings giving the customer a good baseline to begin with. IF they were or are UMI A Arms I would be glad to help the customer get them set back to factory settings. If you have any other questions feel free to ask and I will be glad to help!
Thanks Again,
Brad
Old Feb 6, 2009 | 12:40 PM
Chevy053's Avatar
When I installed my front lower A arms (neither BMR or UMI) I tried to take some measurements and set them close to the stock arms. When it went back on the ground the alignment was way off in so many ways. I adjusted it to get it driveable (mainly toe adjustments) then had a shop align it to the specs I wanted.
I cant imagine how much of a headache it would have been if I had done upper and lower at the same time. My guess would be that having them set to stock specs would help but it will probaly still need finishing touches by someone with and alignment rack.
Old Feb 6, 2009 | 04:14 PM
I have PA racing arms. I need to guess at them but the hemi's are loose. So they are not really set to any length.
Old Feb 6, 2009 | 04:55 PM
BMR Sales2's Avatar
If anything the worst thing is your toe. Bolt the rotor to the hub without the wheel on it. Then take a straight edge (steel stock, long ruler) and clamp it to the rotor face on the bottom. Then if you dont have a straight measurement you can get with a tape measure, hang a piece of string off both ends with a nut or bolt on the end and measure that way.Measure in the front and back and get the two measurements as close as possible and that should get you good to the alignment shop. If the camber looks off just put a bolt on a piece of string and hang it off the top of the fender. Measure the tire at the top and bottom and get those measurements as close to the same a s possible.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Feb 7, 2009 | 01:13 AM
35th SS's Avatar
did the same thing what you did.running umi uppers and lowers rod/rod on both cars.very satisfied with the outcome.
