Where to get different brake lines ?
I'm doing the LS1 swap on my LT1 and want to know if I need LS1 front and LT1 rear lines or LT1 or LS1 lines will work all the way around?
I am getting SS lines so I would like to not have to buy two sets to make this work.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
LS1 master cylinders are not configured the same as LT1's. Lines leading to the rear of your car are not the same as an LS1 either. (the only way the rear lines would be similar is if you had TCS. TCS was only offer in late 95 and would be rare.
For the average user, I wouldn't have opted for SS lines. They will be more difficult to bend and flare. Though they will last longer, for the most part, standard line outlasts most other components on the car. If you need specific fittings or adapters, let me know. I can supply you with any that you would need.
Good luck!
Good luck!
