UMI K-member install help
Just got my car back from the alignment shop. Still havent pushed it yet, but it is riding way too harsh with the konis set on full firm. other than that I am loving it, I think...
I just got the konis dialed in today to a smoother ride. BUt there is still some sqeaking from the upper a-arms. How do you torque them down? I installed them jacked up the on the lower to the loaded position marked it, took it off and torqued it down. But It still doesnt seem like it is tight enough.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Just FYI I got my car back from the alignment shop last friday and the ride is a little bit better with the UMI, I think its due to the weight off the nose and the konis like that setting.
Getting it aligned at the shop was easy, so will working on the car from now on!
This should be one of the first mods that we should do to these cars!
Once again I'm resurrecting an old thread with a question.
I'm currently installing a UMI Road Race K-member into my 1999 Formula.
I'm looking for one of the Threaded Inserts that fit into the body cavity where the K-member mounts to the body.
First off, does anyone have an idea what these parts are called?
I've done a number of searches that include "threaded insert", "threaded mount", "engine cradle body mount" and countless different combinations of these, both thru google and on this site, without finding so much as a picture of one of them. (I really should have included a photo with this post. I'll be sure to update with one later.)
And my second question, where would one find this "Threaded Insert" available for purchase?
Also fellow members, let me say this. I am quite aware that there are numerous ways I can use to fasten these two pieces together. I am not looking for any "This is what I would do..." replies. I want to know what these Threaded Inserts are called and where I can find one. That is all.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
As always, thanks to everyone for taking the time to read my post and respond to my question.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
EDIT: Okay after a lot of digging, I found it.
https://chevrolet.7zap.com/pt/camaro...579976-0-0/#41
Thanks to all.
Thanks to all.
The following users liked this post:
ramairjohn2000 (10-13-2020)
