Quick brake question (C5/LSx Conversion)
Old Mar 17, 2009 | 04:02 PM
  #41
EchoMirage's Avatar
and what is 5/6? is that five sixths of an inch? who measures an inch in sixths??
Old Mar 17, 2009 | 04:05 PM
  #42
6LITEREATER's Avatar
People with small penises I guess... F@ck if I know that is just what I was told.
Old Mar 18, 2009 | 12:50 PM
  #43
equandt's Avatar
My guess is that it was a type-o of some kind. It was probably 5/16" instead of 5/6".
Thanks for the info 6LITEREATER.
Old Mar 18, 2009 | 01:05 PM
  #44
Only thing was he said it to me in a VOICEMAIL and repeated it !
Old Mar 25, 2009 | 07:02 PM
  #45
Killer_Z's Avatar
[QUOTE=76LS1BIRD;11235217]
Originally Posted by 6LITEREATER
It does work for the LT1... I can get whatever you need...
Your bracket DOES NOT bolt to the LT1 spindle.
The C5 rotor is 12.8 "
lt1 guys need to switch over to ls1 spindles. i've read it on all the c5 rotor conversion swap threads there are on here lol. so yeah lt1's need ls1 spindles for the brackets to fit.
Old Mar 26, 2009 | 06:16 PM
  #46
76LS1BIRD's Avatar
Restricted User
There are alot of brackets that will bolt to the LT1 spindle.
You WILL have to do some cutting.
Old Apr 4, 2009 | 07:56 PM
  #47
Heat Seeker WS6's Avatar
ok now for a new twist to the 'brake line length' question.
I have a 93 T/A, and have 02 Z06 rotors, calipers and discs -but not on car yet.
The UMI C5 adapter kit will be here in a day or 2. I have a BMR k-member and Earls braided brake lines on the car already.
Is it likely Im going to have an issue with my lines being too short?
thanks john
Old Jun 7, 2009 | 11:59 PM
  #48
ZMONSTER!'s Avatar
Quick question, would these brakes fit 15 inch bogart/weld/summit type wheels?
Old Jun 8, 2009 | 10:14 AM
  #49
Hugger Z's Avatar
Nope. Corvette's have a 17" front wheel to clear the 13" front rotor. F-bodies had a 12" front rotor and had 16" front wheels. Some people cram 15" wheels on but usually had to grind the caliper for clearance.
