E-brake Problem
Old Mar 5, 2009 | 09:48 AM
bboyxclub's Avatar
Default E-brake Problem
I'm having a problem with my E-brake they won't hold the rear wheels much now. If I'm not incorrect when the ring spands it holds onto the brake disc. I believed that the pin that pushes the ring outward is too small and the ring is not expanding enough. Problably I could make a bigger pins for in there??? Or is ther another way to adjust this??
Thanks
Old Mar 5, 2009 | 05:45 PM
wssix99's Avatar
Save the manuals!
The pin is fine. Have you or anyone else ever changed the rotors? When the rotors are switched out, the e-brake needs to be readjusted - which many people skip. The adjustment is in the star wheel, which effectively "extends" the pin in the mechanism.
https://ls1tech.com/forums/suspensio...nting-sky.html (follow the links here)
If you've never worked on drum brakes before, you might find a friend who has. The adjustment star screw is identical to old school drum brakes.
Old Mar 5, 2009 | 08:19 PM
bboyxclub's Avatar
Thanks a lot I will take a look at that and post back. Thank you again.
