Help Installing Rear Shocks
Old Mar 10, 2009 | 06:20 PM
105's Avatar
105
Default Help Installing Rear Shocks
I'm trying to install some new rear shocks. How exactly do I get to the top bolt to uninstall the old ones? I don't want to take apart my entire interior if I don't have to.
Thanks
Old Mar 10, 2009 | 06:46 PM
Grimes's Avatar
fold down the rear seat, then find the cutouts in the carpet (complete the cut if necessary). peel back the carpet, and take out the styrofoam inserts. That will allow you to get to the bolts.
Old Mar 10, 2009 | 06:51 PM
105's Avatar
105
So I don't have to take out the sail panels? If I do how do I take those out? I have no experience with the interior obviously.
Old Mar 10, 2009 | 06:53 PM
dilatedpeoples28's Avatar
no you dont have to take out sail panels, just peel back the carpet far enough till you can see the styrofoam
Old Mar 10, 2009 | 06:58 PM
105's Avatar
105
I'll give it a try this weekend when I have time again. Thanks.
Old Mar 11, 2009 | 08:51 PM
Grimes's Avatar
no problem, good luck!
Old Mar 12, 2009 | 09:29 AM
z28bryan's Avatar
Like mentioned, the shock mounts to an area behind the backseat. The carpet is perforated on each side for this reason.
Old Mar 12, 2009 | 09:41 AM
riceburnerZ28's Avatar
It's pretty easy ! I did mine for the first time last week. The only hard part was removing the rusted bolts from the bottom.
Old Mar 12, 2009 | 03:22 PM
coolformula's Avatar
Well did you get them bad boys on?
Old Mar 15, 2009 | 03:28 PM
105's Avatar
105
I just got done installing them. Thanks again for the help guys.
