Those with Lightweight Brakes Inside.....
Any trouble slowing down at the track. Iv got a fairly light car weighing in at 3200 with me in it and ever since i put my areospace brakes on up front iv gotta slam the peddle to the floor to slow down in time for the return road. Usually run 11.20's at around 117ish....reason im askin cuz im about to put a new engine in that should pick up much more and i doubt ill stop in time
i know im not leakin fluid and yes i did bleed the brakes as well as play with the proportioning valve. Let me know what i should do..
Thanks Alot, Sam
Thanks Alot, Sam
We trap in the high 170 s and i have stock rears and strange master i did have aero space but now have wilwood. both stop the same. My car weighs 200lb more than yours . My want to look at the MC bore size are try bleeding them if it is a travel not firmness issue .
