Aerospace brake pads, WTF?
So I bought Aerospace brakes out of the classifieds sometime last year, spindles, rotors, and all. So I put it all together and it seems the pads just lay in there? Am I missing a clip or something? I don't see what pulls the pad off the rotor.
Where the pad's ears are that slide into the bracket on top and bottom there should be a small metal clip. I swap these out yearly. Not sure if it's needed that often. I would probably want to make sure it's there at least.
that wooshing noise you hear with your head right next to the rotor? You will not hear that when you are driving down the road. Ive been working on cars for 12 years, that is normal. If there was a gap between the pad and the rotor then your brake pedal would feel horrible. There is supposed to be very very slight contact between the pad and rotor at all times.
it should have a pin that goes through the top of the caliper on one side, then through both brake pads, then through the top of the other caliper. That is all that is needed to keep the pads in place.
