removing rear springs on a 9 inch
I don't have any 9 bolt experience. As long as they sit the same way as they do on the 10 bolt, then you shouldn't have to use a compressor. Did you disconnect the rear swaybar and the upper shock nuts from the interior? When you do that you should just be able to drop the rear axle down.
didn't disconnect the rear swaybar however
they sit identical to a 10 bolt however the perch is ALOT taller.
Chad
I forgot to disconnect my swaybar when I did my springs the first time. The swaybar is mounted on the axle and connected to the chassis. Your axle is hanging on your chassis at this point. Disconnect the swaybar endlinks and you should be able to drop the axle down and get the springs out.
Chad
well just dropped the springs...took about 20 mins and 4 bolts lol...still had to push the rear down to get the spring out but all is well...thanks gents.
Chad
Chad
