possible problems from eibach pro kit springs
Eibach springs for our cars are known for rear spring sag, and the front being higher than the rear is the common stance they give.
Lowering on stock shocks will give you a crappy ride no matter how good the springs are. The stock shocks cannot damper the stock springs let alone lower and stiffer ones. If you want better ride quality you need shocks that can damp the springs (not autozone over the counter shocks), something like KYBs or Konis.
When you lower the car the rear end is "pushed" towards the drivers side because stock these cars have a fixed length panhard bar, this can sometimes cause rubbing issues with tires. If you want the rear to be centered you need to buy an adjustable panhard bar.
They only negative is it encourages you to test the limits every time you go around a familiar curve
http://www.stranoparts.com/partdetai...D=20&ModelID=7
As for the adj. panhard bar I don't think any company makes a "bad" one, UMI will work fine. You may want to call up Sam (his # listed on his website) and talk to him about the advantages/disadvantages of the rod and poly ended PHB's. But in a nutshell a poly ended PHB will make the least noise (no noise) but won't be as "stiff" as a rod ended one. But the rod ened ones can be noisy and may need to be greased every so often. Just depends on what you are looking for.
For most street cars, I can give more valid reasons not to use "coil-over" shocks (or rather adjustible spring perches) than I could give reasons for using them. In fact, many of those who I've encounter bragging about getting them, then install them, only realise later that they can introduce some real PIA issues.
Even though there are only a few decent "direct-replacement" springs for the 4th-Gen F-body, they are designed well enough for both looks and performance.
In short, JD AMG is advice is spot on. Good springs and good shocks will resolve much of your issues in the meantime.
