Will subframe connectors help with traction?
Upped my shot today to a 125 and traction is non- existant.
Car was actually quicker from zero to 60 on the 75 shot just because the tires didn't spin.
What do you think?
Subframe connectors tie your rear end of the car to your front end of the car reducing shakes and rattles, improving handling and turning.
What you need to catch traction are LCA relocation brackets... and LCA's... They make the angle of your LCA more directed towards the ground forcing more traction with weight. They come like that on most of the 9" or Dana's that people buy. I'd be careful if it' your stock 10bolt, however since yours is an automatic (**edit** they're not stronger, rather the transmission doesnt cause as much destruction as an M6 does** ty for the correction) i wouldnt worry about it.
What you need to catch traction are LCA relocation brackets... and LCA's... They make the angle of your LCA more directed towards the ground forcing more traction with weight. They come like that on most of the 9" or Dana's that people buy. I'd be careful if it' your stock 10bolt, however since yours is an automatic (i've heard the automatic 10bolt is stronger) i wouldnt worry about it.
But at least i dont have a gold camaro... tool.
If your goal is to plant for a 1/4 mile run, you should probably look into LCAs, relocation brackets, and/or a new torque arm.
You can use the LCA relocation brackets to change the downward forces during the 1/4 runs, then change them back for "normal" street driving.
.If you're looking to improve your drag race launch, skip the SFC's and go with LCA's/brackets (if you're doing ONE or THE OTHER). If you want to go all out, do both, although realistically, the improvement will come primarily from the LCA's.
From a handling perspective though, when the car acts like a big "spring", it doesn't do any favours for the suspension. The springs and shocks are supposed to take the bumps, and control the ride ... the chassis isn't supposed to be part of that "moving" suspension
.From the drag racing perspective, it is true that some of the energy will be wasted twisting the frame. However, the OP's problem here is TRACTION. Putting even more power to the ground isn't going to help improve that, now is it????
They do, however, provide a GREAT jacking point from the side of the car, as stated!
Sub frame connectors and Lower Control Arm Relocation Brackets would be a great improvement when it comes to traction and handling! The sub frame connectors will keep the chassis nice and tight and eliminate body roll and like the others mentioned help at the strip with fender dimples..And the Lower Control Arm Relocation Brackets will allow you to adjust the lower control arm more parallel to the surface and allow you to plant the tires and keeping the power where it should be to the ground! If you have any other questions feel free to ask and I will be glad to help!
Thanks Again
Brad
