For those who have the C5 brake upgrade
no one?
do the c-5 brakes grab more. like i know they do. but can you feel it. also if you put like the cts-v brakes on(brembo 4 piston) will it grad harder. like normally there is a split betwwent he front and the back. like 60 40 or what ever it is. when you put the bigger brakes on does it change the split. to like 75 25? thanks
c5 and ls1 brakes have about the same grab on the first 60-0 stop. its the multiple stopping that does it. the ls1 brakes tend to flex when really hot and the c5 calipers will not. the rotors will make it to where they do not warp as easily. if you want more grab go with something else.
no one?
This seems to be what most people are missing. Unless you swap to a pad with a MUCH larger surface area, the brakes won't really grab that much harder than stock on the first stop. Multiple piston calipers allow for less pad taper and larger pads. The more you are on the brakes, the hotter they get. Larger diameter rotors disperse heat better, improving "hot" braking.
THIS is the big thing that people are missing, you're maximum braking is determined by your tires and suspension (how much weight is transferred forward) you dont want too much weight transferred since then you're more prone to the rear locking up...which is not good...but in summary its the tires that affect shortest breaking. What you're gaining with bigger calipers and rotors is heat fade resistance. Sure i can get my tiny *** LT1 calipers to lock up the tires and it is true that me and an LS1 car can go from 60-0 in the same distance (assuming identical tires, suspension, etc.) THE FIRST TIME...now guarantee you if we were to "hot lap the test" the LS1 would be FAR superior every test afterwards. Essentially if you can lock up the tires, you are at maximum braking force applicable, its after that first hard corner that the bigger stuff shines through supreme.
It makes sense that the C5 calipers would have smaller pistons in the front since their f/r weight bias is closer to the center of the car than ours.
From what i understand the piston in the C5 caliper is actually smaller than the f-body one which actually shifts the bias rearward, add that to the bigger pad and rotor and it probably brings the bias back towards the front a little. Maybe we break even. Correct me if i'm wrong somebody.
#32
This would totally screw up your bias. It might be decent if you had a HUGE setup in the front. There was a guy on the corvette forums that did this. Huge bbk up front, and stock fronts in the rear. Just because it CAN be done, doesn't me it SHOULD be done.
#36
I found the thread on the rears.
It's an old thread and really doesn't say that much.
http://web.camaross.com/forums/showthread.php?t=364817
#38
Night and day difference. I just installed my C5 brake kit yesterday (after 2 years wait) and went on a cruise today. It stops at a dime. You can get a used C5 front caliper for about $100-150.
You guys might also wanna consider the CTS-v brake upgrade, more expensive but more effective.
#40
There is no difference for the rears. You can use the calipers but not the rotors. Then you use the vette pads and the vette clips. There is really no difference in performance or looks of the vette calipers. I was going to do the same thing but have since changed my mind.
