Traction problems
Old Apr 19, 2009 | 01:39 PM
T-Pat's Avatar
Default Traction problems
Ok, I'm tired of getting my @ss spanked off the line when I race due to not being able to get traction. What are some good ways to gain a little traction with a stock '01 SS suspension, 4L60E, and with street tires? Any and all suggestions welcome! Thanks!
Old Apr 19, 2009 | 02:06 PM
dragonrage's Avatar
What tires? Not all street tires are the same. It's like going on a general car forum and saying "My car isn't fast enough. It's a Chevy. What do I do?"
Old Apr 19, 2009 | 04:41 PM
T-Pat's Avatar
ha, ok good point, the tires are riken raptor series 265/75/16. hope that helps out a little.
Old Apr 19, 2009 | 05:18 PM
BobDoLe's Avatar
why are you on a 16inch rim with your 01 SS?
i had riken raptors. i couldn't get traction with those. car would go sideways quite a bit just shifting into 2nd (auto trans).
i hate to say it, but if you want traction, you're going to sacrifice treadwear.
a couple guys on here go with falken azenis rt615 (i have them up front) which are pretty grippy but not really enough even then.
i'd recommend R compound tires (which get really soft and sticky when they heat up). if you're already running and complaining about 12.90's now, your best bet is to get some nitto 555R drag radials on the back at least... or go with a full slick on a separate rim that you can swap on for the track.
i found a really good cheap suspension mod for traction to be lower control arm relocation brackets
Old Apr 19, 2009 | 06:44 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
LCA relo brackets.
Old Apr 19, 2009 | 11:19 PM
T-Pat's Avatar
The car was a repo before I got it and some of the good stuff was taken off of it before I got ahold of it (wheels, power seats, etc.) so I'm stuck with 16" stock rims. But I know what you mean about sliding sideways when shifting into second because thats exactly what mine is doing. So it is sounding like better tires are the only reasonable option at this point?
Old Apr 19, 2009 | 11:36 PM
Elliott's94Z's Avatar
LCA and brackets and either some Nitto DR's or MT's. The Raptors are **** for traction. I've got a set of 4 sitting new in my garage if that tells ya anything What kind of suspension work do you already have done?
Old Apr 19, 2009 | 11:46 PM
T-Pat's Avatar
Personally I have done nothing to the car but I noticed the tag where it says the car was sent to SLP and the it has bilstein shocks and springs all the way around. Thats the extent of what I kno has been done to this car.
Old Apr 19, 2009 | 11:57 PM
After I did the LCA w/ brackets, panhard bar, torque arm and SFC I noticed a big change in traction and obviously handling. I would contact Ryan at UMI and see what he can do for you on some suspension goodies. Don't forget them tires too. My Raptors just sat there and spun like no tomorrow I'm running BF KDW's now.
Old Apr 20, 2009 | 12:17 AM
lt1noob's Avatar
kdws here too, love them but once they're gone im going nittos for sure. and yes, just get ahold of someone from umi and theyll have you launching proper in no time.
Old Apr 20, 2009 | 12:20 AM
T-Pat's Avatar
Sweet, thanks for the info, looks like I'm gonna junk the raptors for now, at least the back ones anyway, and look for some LCA brackets. Thanks again!
Old Apr 20, 2009 | 12:21 AM
spy2520's Avatar
damn dude those are some big *** tires.
Old Apr 20, 2009 | 12:32 AM
T-Pat's Avatar
Ok you made me get up and look, I tried to remember what they were but I was a lil off. They are 225/50ZR16. Sorry about that.
Old Apr 20, 2009 | 01:55 AM
HWI's Avatar
HWI
Get LCA with relocation bracket, panhard bar, and some 10.5" wide rims with some 295 or 305 tires. That should get you started.
Old Apr 20, 2009 | 07:10 AM
UMI Sales's Avatar
Thumbs up Lower Control Arm Relocation Brackets...?
Hello
If you are having traction problems! I would recommend a set of Lower Control Arm Relocation Brackets. They allow you adjust your lower control (We have experienced the best performance setting is the lowest setting on the brackets) They are designed to eliminate wheel hop and Improve your traction performance! Below is a link to show you what we have to offer. If you have any other questions feel free to ask and I will be glad to help!
http://umiperformance.com/products.php?category_id=125
Thanks
Brad
