Paner rod?
Old May 3, 2009 | 02:22 PM
PONTIACTRANSAM94's Avatar
Default Paner rod?
Im puttng on lowering kit on my 94 trans am. Will i have to buy a adjustable paner rod to center the rear end or can i still use my stock on
Old May 3, 2009 | 02:26 PM
Sommer86's Avatar
It's called a "panhard" rod ...and no you dont "have" to...but it's suggested. I ran the stocker for a year after lowering my car.
Old May 3, 2009 | 02:30 PM
My bad on the spelling of that. But you can line it up with the stock one for right now?
Old May 3, 2009 | 03:52 PM
99Bluz28's Avatar
The stock PHB isn't adjustible, but as long as you don't try to run really wide tires you shound be fine with the stock PHB for now.
Old May 3, 2009 | 04:04 PM
Well on the back right now im running 255/50/16 so that size should be ok?
Old May 3, 2009 | 04:47 PM
slingshot928's Avatar
You should be fine, that is like the stock wheel on the fbody. I just switched to a umi single adjustable, what a fine piece to have on my car.
Old May 3, 2009 | 05:07 PM
They come factory with 245/50-16 all the way around. Im running right now 245/50-16 up front and 255/5016 on the rear
Old May 3, 2009 | 05:11 PM
ae13291's Avatar
were talkin if you are running some c5 18" wheels or bigger. ur stock 16's are ok
