Installed LCA relocation brackets, not centered
They are a little tricky! Sometimes you have to loosen everything up on the rear end. And make sure that you don't get the rear end into a bind and make sure all the holes line up especially the factory location seeing that is how you get the main setting. If you have any other questions feel free to ask and either Jerry or I will be glad to help!
Thanks
Brad
The instructions included with the brackets are the correct procedure. A clunk would usually signify a loose bolt or bolt tighten but not enough. We have techincal support available every day from 8-430pm EST if you would like to speak with them or e-mail Jerry at jerry@umiperformance.com and he may be able to help but he prefers the phone.
Thank you,
Ryan
Hope that helps,
Ryan
MLS
If I can help anymore please ask. Thank you!
Ryan
Instead of getting adj lca's, I just poked and extra set of holes in the brackets. Brought the rear closer to centered. I think it will work just fine.
I was a little concerned about how close to the other holes the new holes might need to be, guess I'll find out if I have this problem, as I've just bought some........
my UMI bolt ins worked fine with stock LCAs.
