Installed LCA relocation brackets, not centered
Luckily, I already have UMI adjustable LCAs as well so I can return my rear back to where it needs to be. I think this will bottom out my adjustment range though, or at least take it very close.
Bottom line is its better to have adj lca's so you can correct it, if it does turn out uncentered.
Unfortunately I ordered non adj lca's with my relocation brackets
Want proof? I went out and reinstalled one and took pictures:
http://www.darklogic.net/BadUMIReloBrackets/
If you notice, having the rear end in 'driving height', swinging the control arm down, bolting in the bracket, and swinging the control arm back up, IT DOES NOT LINE UP in EITHER set of lowered bolt holes. If you notice, with the bracket then removed, it swings up perfectly back to the stock mount point perfectly.
It is obvious that the 'arm' on the relocation brackets that bolts where the shock does is WRONG!
I called UMI before on this, I sent them measurements, and they STILL said it was correct. By this pics it is OBVIOUS it is NOT!
Hell, by the pictures supplied by UMI of thier own brackets in teh instructions you can see visually that the 'arm' on the brackets is much shorter on the ones I received. They say they never changed them, but it is obviously shorter. The pics I provided on the install PROVE that.
I ended up cutting the arms off, grinding off the powdercoat and welding the brackets in.
At this point I just want the $30 difference in weld-in vs bolt-in brackets. I purchased the brackets through Byunspeed, so who do I contact to get a refund?
I will say it is horrenous for a vendor to claim there is no problem when it is BLATENTLY obvious they had a bad batch. They claim it couldn't be, but I have done CNC machining (including wire-edm and other forms of cutting) and it is VERY simple to modify a program either before posting it to the shop or even on the machine itself. One dimension change by someone and BAM! a whole batch is bad. To lie and claim it is not is just bad business. To not want to accept something like a batch of relo brackets back and then just sandblast them and cut off the arms to make a batch of weld-ins just does NOT make good business sense...
Also, to add more data to this, the install was on a 1995 Camaro Z28 with stock rear. I also tried fitting these to a 1994 Z28 stock rear ad a 1997 Trans-Am with stock rear and all had the EXACT same issue. There is NO WAY to fit these brackets differently, so "install error" is a non-issue. They only bolt in one way. And you can see by the pics provided that they were installed the only way they can go on.
I just want my $30 refunded to me at this point. I would LOVE to be able to get refunded for my installation hassles (cutting the brackets, grinding off the powdercoat, welding), but we all know THAT won't happen.
And the sad part is I really LOVE the UMI subframe connectors. I was planning on going with a UMI Torque-Arm this year, but the major let-down of a badly produced part with the relo-brackets really soured me on UMI. I mean why would you risk future sales over a $90 part??? Just produce the right part and exchange the bad ones... Greed too many times really screws up business.
I mean, if GM changed rear end geometries (which would mean they also changed the rear lower control arms), and certain rear ends need different setups, why isn't this a well-known issue? I mean you state you installed one of these 'defective sets' on your own car??? How the hell is that possible if it is a 'factory' rear??? Again all of this does NOT add-up. (and for reference I tried teh install with both Global West control arms on my car and stock control arms on teh other cars, so no adjustability was available for a 'quick-fix', or hmm, is it possible that is your 'solution'? Sell adjustable LCAs???)
Oh, and if you had not noticed, I am just a little pissed by the stonewalling attitude that there is no problem with the part, and the obstinance of denying it.
Pic:
You can see the bottom flat of the L portion flat against the shock mount on the far right of the pic.
if my car wasn't lowered, the wheels would have been centered in the wheel wells. i noticed this when i was loading up the rear with a jack to check.
i just adjusted the (adjustable) lca's by 1/2 inch each and now the tires are centered in the wheel well. i'm still driving around to make sure there's no rubbing issues, but so far it seems fine.
I guess I may have to resort to posting a link on thier visitors page to get them to respond???
. which brings me to wonder who came out with it first
here are before/after pictures of the passenger side.
this is a bad picture for the angle, but you can get a good look at the space between the forward facing part of the tire and the body.
with aftermarket lower control arms (spohn adjustable rod/poly) at stock length (measured at bolt holes).
after shortening the lower control arm 3/5"
before and after the adjustments, the front/rear wheels were the same distance (measurements taken with a tape measure, flat on the ground against chalk lines made using a ruler lined up with the center of the wheels) from each other as compared between driver/passenger sides, so it wasn't a sloppy install. like everyone else is implying, it just looks like there isn't enough of an arc built into the relocation bracket.
what else could it be?
One customer sent his back and they checked out ok, we randomly pulled sets out of stock and they are ok as well. We personally installed them on my vehicle.. the set sent back moved the rear 1/16 of an inch. If you have problems please call Jerry in technical support and he will be glad to help you.
Our phone #- 814-857-5400
Thank you,
Ryan
If you would like to provide feedback about UMI or any sponsor for that matter, please do it in the sponsor feedback section.
Thanks,
MLS
