Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird Brake Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
Super Cheap Big Brake Kit - Info
#42
wow just seen this nice write up. looks easy and inexpensive compared to other BBK's these setup w/ 14" rotor should clear a 18" deep dish ZO6's. since they clear the 6piston already i assume, but u know what happens when u assume lol.
#43
Those rims should work fine. If the spokes are a tad too close to the caliper, a quick trip to the auto parts store for some thin wheel spacers (3/32") will fix you right up. Or you could buy them in advance and just return them if they're not needed.
#46
Good thread for anyone who wants to setup a big brake kit without dishing money for Brembo calipers.
#48
From post #3:
Q. These fronts are way cool. Can I use the CTS-V rear calipers on the back of my F-body to have a matching set?
A. I haven't done any research at all on retrofitting the rear brakes. Sorry.
#49
so running the setup alone will push the wheel out ?????
and if i need a wheel spacer 2 clear the caliper that will push it out even more
i only have 3/4" from the spoke 2 the caliper
#51
Awesome write-up guys! I had a C6Z06 set-up to go on my car but the caliper would still not clear my C6 Z06 wheels when I mocked it up. Still needed a few mm to clear and I didn't want to run a spacer. I was also not overly thrilled with the track complaints on those calipers. I am definitely going to look into these calipers for my car since I already have the rotors. And definitely going to try to put the rears on the car as well. Gotta love the Brembo caliper shape.
I will be sure to get pics if I can pull all of the parts together this year. If not, that is definitely on my winter project list.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#52
I will be sure to get pics if I can pull all of the parts together this year. If not, that is definitely on my winter project list. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Hmmmm, now you have me wondering if the newer CTS-V 6-piston front caliper would fit......
#53
^^^ i am in process of try the new 09cts-v calliper and the zr1 caliper. i will let ever one know how that goes.
thing i cant find anywhere is what is the size of the cts-v rotor. dia? and think?
#54
Sweet! I know the ZR1 caliper has the same attachment points as the other vette calipers. I am wondering if the new V caliper has the same points as the old one or of they changed the knuckle interface. Not sure about the rotor though. That is not published in a magazine article or anything on the car? It set so many records and received accolades. It's gotta be somewhere.....
#59
FAQ
Q. Will my current rims fit?
A. That depends on several factors. First of all you will usually need an 18 inch or larger diameter rim to prevent the inside of the hoop from touching the caliper.
The second aspect concerns spoke clearance. This is where you get lots of different variables based of the shape of the spokes as well as the rim width and offset. If the spokes touch the caliper then you will need to space the rim outward. The easiest way to see if you will need a spacer or adapter is to measure your stock brake setup (12" LS1 rotor and caliper) and see if you have 1" of spoke clearance. Once you take into consideration the new rotor offset and the new caliper thickness, the conversion will stick out 1" more than stock. Measure the approximate area shown in the pic below.
#60
