Pre-bent brake lines for a 95 Z28?
Does anyone know of a place to get pre-bent front to rear brake lines for 95 Camaro? I have found a place that makes 82-92, and 98-02 but skips over 93-97. He even said he probably has 96-97 but for a traction control rear only. The one on my car has rusted through in a couple spots.
Which lines do you need?
The body lines from the ABS pump to the rear flex hose?
Or the 2 lines connecting to the distribution block and going to each caliper on the rear diff?
Or both?
I'm about to strip the body lines off of a 96 TS car. They are yours if you want them. They will be a bitch to ship ...
Otherwise, do what we do and convert everything to to 3/16" steel line from Autozone and -3AN flex lines.
Or both?
I need the line from the ABS module to the rear that attaches to the brake hose on the rear end. It rusted through right next to the bracket on the frame.
I really hate trying to make brake lines especially when you are working on a creeper and you need to keep sliding out from under the car to make another bend.
