sitting uneven on level ground??
Some say GM designed it this way so that when you sit in the car, it is even. Have someone verify that while you sit in it. FWIW.
1) Coilovers - since they are adjustable for ride height
2) Ground Control makes adjustable spring perches that can be used with standard rear coil springs (although I have no personal experience with them).
3) Some sort of spring spacer (I believe LG used to have these) that you could use with the pass. side spring to slightly raise that side.
On the fronts, the coil has a specific place in the isolator that it sits. If not seated all the way, it could raise the car slightly.
Same with the rear.
But I echo what the others have said ... screw what it looks like in the driveway, how does that bitch handle turning?
