Front End Alignment Nightmare!
It shouldn't take weeks, it should take minutes. If it doesn't stop bubbling/gurgling within a minute or two, using the method I described, then there's something wrong. Possibly a bad rack, possibly lines that aren't connected tightly, allowing air to be sucked into the return line (the o-rings are in place, and OK, right??), possibly incorrect fluid in the system....
Because of the tornado that came through my area it has been a mess and I have not been able to take the car in to another alignment shop that was recommended to see if they can figure out what is going on. I am going to try to this weekend to jack the car up again and try the 12 and 6 o'clock tug to see what I get. The noise and shimmy of course is driving me crazy but everyone's power was out for days to a week and lots of damage everywhere.
The clank noise that started after the rack and outer tie rod ends were replaced is only on the drivers side and I can't figure out what it could be. It only does it when there is a load on the vehicle like braking sometimes quickly or taking off. It does it when there is a driveway where the tire on the drivers side pivots from the uneven driveway or like if there is a slight dip it will do it sometimes. Sounds like metal on metal and a definite clank. The engine mount was loosened to raise the engine.
Have the rubber bushings and ball joints ever been replaced (on the the front upper/lower arms)...?
Have the front hubs/bearings ever been replaced...?
Have you ever damaged the front suspension by running over anything (kerb, pothole)...?
Has the car ever been in an crash/accident...?
Steering wheel still jerks to the left when I cross speed bumps and such like it never did before, clank noise, and steering wheel shimmy comes and goes all still there.
If this is too costly I am not sure how to advise you.
That is what I did to my car. The labor was all me and I still didn't like the price tag.
See if you can borrow some ramps, get the front of the car up on them, then place a 12" piece of a 2x4 across your jack's "cradle", and lift the lower control arms, one at a time....If you can't locate any ramps, go to your local lumber yard, purchase a 10' length of a 2x10, have the lumber yard cut it into 4 pcs, with one end bevelled at 45 degrees. Nail two together, to make a pair of 4" high "ramps". Then proceed as described above.........
