Tunnel Braces
Old Jul 7, 2009 | 05:53 AM
ls1owner4life's Avatar
Default Tunnel Braces
What do they do and are they worth the $
Old Jul 7, 2009 | 07:12 AM
UMI Sales's Avatar
Hello
I take it that you are asking about the tunnel mounted torque arms??? Well if you are they mount to the body itself rather than the transmission. But seeing how a shorter torque arm itself is used it transfers weight a lot faster than a full length arm. Therefore giving you maximum performance. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...te4rcm1jrml6j4
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Old Jul 8, 2009 | 08:20 PM
Can you make me one that looks like this?
I dont understand why you dont offer one. I would prefer a UMI product and want one that will match all of my BLACK UMI parts.
Old Jul 8, 2009 | 08:41 PM
JamRWS6's Avatar
I was just looking at this the other day and was shocked UMI didn't have this part as well.
Old Jul 8, 2009 | 08:43 PM
Breathing Fire's Avatar
I have a tunnel brace, but the only reason I got one was to stop the Ypipe from banging the stock one. I didn't notice any difference with it. Nice to not have the Ypipe banging now.
Old Jul 9, 2009 | 09:21 AM
00 Trans Ram's Avatar
They don't do that much. The car very rarely wants to send enough loads EXACTLY perpendicular to the longitudinal axis of the car (the kind of loads that would make this necessary). Especially enough loads to where the stock piece will bend or fail.
Looks like a solution in search of a problem.
Old Jul 9, 2009 | 12:03 PM
StuntmanMike's Avatar
You know, I just noticed this part on the website the other day and was thinking the same exact thing.
I'm sure in some extreme case it will help out, but for the most part it looks like something for people who just like bolting up stuff to thier car.
Old Jul 9, 2009 | 12:18 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
The one thats on the car from the factory is stamped steel and basically does nothing. Most people take the tunnel brace off. If your heavy into corner carving or road racing it will help keep some flexing out of the floor. If you have any questions please give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jul 9, 2009 | 12:27 PM
Sam Strano's Avatar
LS1TECH Sponsor
Useless part.... Another example, IMHO, of parts built to fill the need some have to just change things, rather than do a specific job. The car has a brace on it stock, and if anyone tried to bend it, they'd realize that because of the bead rolling and lip on the edges it's not weak.
However this is a bit silly. If you want to keep flex out of the car then you want SFC's, not that little brace. For that matter you'd want 3 point connectors over 2's to triangulate the floorpan. I find it odd that a company would make a brace like that but not 3-point SFC's. Would it be bad to add that? No--just not a tangible help. and I can think of about 50 things I'd rather spend money on.
__________________
Old Jul 9, 2009 | 03:29 PM
Arc00TA's Avatar
Okay so this got me to wonder, I have 3 point SFC's that bolt to the tunnel brace mounts, but no tunnel brace. Would there be any reason or improvement in the effect of the SFC's to have a brace between the two? The mounting pads for the brace are very flimsy looking, so I don't know what kind of support they are offering the 3rd point of the SFC's.
Old Jul 9, 2009 | 05:33 PM
leadfoot4's Avatar
Originally Posted by Arc00TA
.... The mounting pads for the brace are very flimsy looking, so I don't know what kind of support they are offering the 3rd point of the SFC's.
That's what I've always thought.....However, since my car is a little "old school", I have the Kenny Brown Racing "double diamond" subframe connectors They tie in at the subframes, and 4 points along the rocker panel, as well as the tunnel brace mount points.
I did have one of those braces that's pictured here, but all it did was kill my ground clearance...
