How to stop the clinking from my LCAs?
How would I go about stopping the clunking noises from the LCAs when i drive over an uneven surface? Is there even a way to stop it?
check the lower ball joint. i cant remember if there is a grease fiting on the stock ones or not, if there is, fill it full. my bmr lca was doing the same thing, and i greased the hound out of the ball joint and no noise. if there isnt a grease fitting then replace the ball joint.
