Grrrrr caint hook " need advice "
well guys my mods are in my signature.... Seems now after I have tinkered with the rear end I caint get the car to hook for ****.. Before on stock suspension stock 10 bolt with 3.42 gears the car hooked solide with the 26 10 M/T et slick.... Now that I have put 9" under 4.11 gear full spool... torque arm, lower control arms, and relocation brackets, panhard bar, and BMR extreme anti roll bar on car It will not dead hook... I couldnt hook it on the et slick, I tried running a M/T et street 28 11.50 this past weekend and it just blows them off.... I dont know what the problem seems to be... any advice or anything would be great! By the way im leaving anywere from 4500 to 5200 also leaving on the full kit 150 shot.... The car cut a 1.46 60ft time with stock 10 bolt and stock suspension............
HELP ME please lol
HELP ME please lol
A suggestion for you!
Hello
Sounds like a weight transfer problem! What type of spring and shock combo are you using? Might want to look into a 275 or 300lb front spring and a set of adjustable shock. Below is a link to show you what all UMI Performance has to offer.
http://umiperformance.com/page.php?page=genfbodyshocks
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
HELP ME please lol
HELP ME please lol
Another Suggestion for you!
http://umiperformance.com/products.php?category_id=118
Thanks
Brad
Assuming he has stock springs and suspension, do you really think that those 275 lb springs are going to dramatically change his launch? I mean he changed a ton of parts.. anywhere along that way it's possible he may have something set improperly.
I'm pretty sure that you gotta adjust your input when you go to a higher gear like 4.10. People who have gears at my races say that I should stick with my 3.42's because with my 400 hp I'll be all messed up with my launches.
I've heard the torque arm pinion angle can make your launches worse depending on what it's set to.
I'm no drag expert.. but I figured I'd toss ideas out there. You hooked well on stock springs and then changed a ton of parts but left in stock springs and didn't hook well. Seems hard to believe that going from 293 lb springs to 275 is the solution to the problem when you did fine with stock springs originally.
Like Lee said you have the right parts to get the job done. Give us a call here at the office and we can get you headed in the right direction. A few minor adjustmensts and you will get the results your looking for. Our tech dept is open till 6pm est mon-fri.
