Rod end size on wolfe double adjustable LCA's
does anyone know the rod end size on the wolfe double adjustable lca's using the stock bolts.
mine have about 30k and a ton of races on them and are making a bunch of noise and the car is starting to track very poorly and dart around when cruising so i figured i'd start by replacing them and see if it gets better
i sent them a few emails with no response and the last time i called it just rang
thanks
thanks
