Anyone try an elec. vaccuum pump 4 brakes?
hey guys i was just wondering if anyone has used an electric vaccuum pump for their brake setups... stainless steel brakes makes a vaccuum pump and here is the info on it...
When using a supercharger or a big cam, chances are there's not enough vacuum being generated to operate power brakes. At least 16-inches of vacuum is needed to properly run a power brake booster. This vacuum pump kit will provide the proper amount of vacuum to the booster so it can operate correctly.
just wondering cuz this would be a cheaper way out then buying a bigger brake system...
btw, how do you guys like wilwood brakes? thanks guys.
