My Bushings are failing
My front suspension bushings are all going bad. I changed the uppper a arms because the bushings were so shot that the wheel would move left to right with ease with wheels off the ground. As soon as the Aarm was removed the bushings fell through the holes! The lower a arms also have significant rubber loss on the bushings(bare metal)! The lca(rear) were replaced for the same issue.The car is a 2001 camaro ss and has 83k on it
Hello ,
I think you don't have to waste your money and time for OEM bushings that cannot go with high performance cars or bad weather conditions ( more heat , more cold and more rains will damage stock and OEM bushings )
You have the choice to pick Energy Suspension or Prothane Bushings kit
Here is the hyper-flex Energy Suspension full kit ( all required bushings " for more details see summit ) and it comes with red and black color
http://www.byunspeed.com/product_inf...ducts_id=11794
and here is Prothane full bushing kit and it also comes with red and black
http://www.byunspeed.com/product_inf...ducts_id=12802
poly front control arm bushings is a bad idea. they wont last as long they cold flow then you have front end tracking problems then you get pissed off when they cant aline your car anymore. save you a headach just get the rubber replacement. trust me ive had both on my 94.
