1st suspension mod?
Thanks in advance.
R.E.Z.
I just noticed that you were looking for some suspension suggestions. What are your plans for the vehicle? Well I just wanted to leave you know that UMI Performance has a wide variety of aftermarket suspension parts to offer! Below is a link for you.
http://umiperformance.com/93-02fbody
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks in advance.
R.E.Z.
welded SFCs are planned but my buy fell through locally and shipping costs more than the part. I'm just trying to figure out which of these I should do first since I don't have the means right now to get it all at once *thank you wrenchitis and premature tire death syndrome* and Just have the LCA's right now.
I was also thinking either adj. panhard or torque arm as primary candidates for first pick, good to know i'm not a retard
Thank you all for your time.
Oh yea, I have both BMR and UMI products
BMR guy, Thx i'll keep it in mind, I like your products but shipping here is ridiculous for anybrand./thread.
I would go with either Strano spec Bilstiens if staying with stock springs, or Koni SA's with Strano springs if planning on lowering. I'd get a good set of 35mm/22mm swaybars or similar combo. Double rod end adjustable PHB. Some really sick rims, with at least a 10-11 inch wide rear set to intimidate the local noobs and ricers. Keep the LCA's and torque arm stock because what do you need to improve those for if you're just f*in around on the street?
Unless you get wheel hop.... If you end up getting wheel hop, then I'd go for some LCA relos and rear LCA's or swap to solid moog bushings on the stock LCA's. Or try a torque arm. I'm all about trying one part at a time. If you don't have wheel hop or one part fixes wheel hop, what do you need the other for? (unless there's another reason)
Don't just toss parts at your car. Figure out how you want to change your car, and then apply the appropriate part to it.
