Caliper fell off.... Again
Oh, try PM partstaxi or SDPC. Maybe get a pair of used bracket with guide pin and bolt here or junkyard.
I really don't think your drag pack cause the problem. Think about the srteet condition is not perfect. It gotta be something wrong mechanically.
Closed ex-Sponsor Account
That does seem a little steep. Give me a call or shoot an email and I'd be glad to help you out.
Thanks
Kevin
www.PartsTaxi.com
Thanks
Kevin
www.PartsTaxi.com
Well I went around all the breaks today and pulled everything... I cleaned all of the bolts and threads on everything, and got a few new bolts I needed. After cleaning everything I went back around and put RED loctite on everything and torqued the bolts down as close to spec as I could guess just by hand (didnt have torque wrench). And I deflated the air bags as well so the ride should be a lot smoother with much less vibration. No reason I should have this problem again... Hopefully I dont.
AND while I had the wheels off I did realize the this **** really did damage my wheel. I can see and feel little "dimples" on the metal on the inside ring of my wheel where the bracket got stuck... I must say I am a little pissed off about that one. Looks like I need to hunt for some spare wheel parts...
How in the heck do you guys have bolts just "come loose"?!?!?! I have NEVER used a drop of Loctite since whatever the factory put on, I've had the brakes off and back on NUMEROUS times (swapping pads for the track, etc.) and my car has almost ~80k miles on it!!
Maybe you just need a little more muscle next time you install the bolts?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Save the manuals!
Until you get the proper torque on the bolts, all of the locktite in the world and voodoo magic won't help you. If you under torque, the bolts will vibrate out. (even with locktite) If you over torque, you could over strain the bolts and cause them to yield. Either condition is unsafe.
Unless you are taking roids like a homerun king, I doubt you can get a full 75 ft lb on the caliper bracket bolts. That's a lot of force in a very awkward place. (The torque wrench will give you additional leverage.)
