stock torque arm
Old Jul 5, 2009 | 03:29 PM
95Banshee's Avatar
Default stock torque arm
i am planing on getting a torque arm sometime this summer but for now i was thinking of welding a few reinforcements to the stock one does anyone think this might help. im not looking to make the stock one bullet proof or anything and im not expecting much improvement. im just board and thought about trying it.
Old Jul 5, 2009 | 04:26 PM
SuperSport01's Avatar
If you plan on replacing the torque arm, I wouldnt waste the time or effort modifying the stock one. But if you decide to anyway post up your results please.
Old Jul 5, 2009 | 05:59 PM
leadfoot4's Avatar
Personally, I wouldn't bother, unless A) you're making a TON of power and have an equal amount of grip, or B) you've altered the ride height and want to adjust your pinion angle.
Old Jul 5, 2009 | 10:21 PM
95Banshee's Avatar
i am trying to get rid of the rear end twist i am getting when i slam second gear i can just feel it try to rotate under me. i am just looking for a temperary fix. and i have time and access to matearials. so i just wondered what others thought. and i am not making it adjustable.
Old Jul 6, 2009 | 07:16 AM
UMI Sales's Avatar
Hello
Another suggestion for you would be a set of lower control arms! Seeing how the stockers are just a stamped piece you are possibly feeling a lot of the flexing going on and the bad bushings. Below is a link to show you what all UMI Performance has to offer.
http://www.umiperformance.com/catalo...7cekol0fvhpkl1
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Old Jul 6, 2009 | 05:35 PM
95Banshee's Avatar
lol i just ordered LCA yesturday so i am hoping u are right and that gets rid of the flex.
Old Jul 8, 2009 | 05:23 PM
95Banshee's Avatar
got my lca installed and now that they don'y flex any my trans or torque arm are slaming against the trans tunel so now i need a torque arm.
Old Jul 8, 2009 | 05:55 PM
leadfoot4's Avatar
No, it sounds like you need a tranny mount cushion. They've been known to fail......
Old Jul 8, 2009 | 06:49 PM
95Banshee's Avatar
i have a poly trans mount
Old Jul 8, 2009 | 06:55 PM
tittan1500's Avatar
well that is broken or you messed somthing up bad because your tq arm is not hitting the body if it is in good shape.
are you sure the sound is not a clunking /slaming from the lcas not being tight ?
Old Jul 9, 2009 | 03:04 AM
Nitroused383's Avatar
You have a poly tranny mount, well you probably need the poly torque arm mount. Its not hard to replace at all and I am sure the stocker is shot.
Old Jul 9, 2009 | 07:09 AM
UMI Sales's Avatar
Thumbs up UMI Performance!
Hello
I would just suggest just checking out the bushing just to make sure that your stock torque arm did not cut through it! They have been known to do that! And hopefully the torque arm mount on the rear of the transmission (clam shell) is not broken. If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Old Jul 9, 2009 | 06:23 PM
95Banshee's Avatar
ill check it out but sence i am planning on getting a tunel mount tq arm im not too concurned.
