end link length?
Old Jul 7, 2009 | 07:06 PM
ls2 bait's Avatar
Default end link length?
does it matter how long the front endlinks are on the sway bar? i have seen a few that are fairly short. just seeing if that might tighten up the suspension a bit?
Old Jul 8, 2009 | 07:37 AM
Major_Lee_Slow's Avatar
Ideally you want the sway bar arms to be parallel to the ground. if the vehicle is lowered then the endlinks need to be shorter. HOWEVER if you go too short then the links are actuated all too much of an angle during hard corning and single wheel bump events which will lead to premature wear. So it's a compromise.
The stock length is 100 mm on center and I wouldn't recommend going much shorter than 90 mm on center.
Old Jul 8, 2009 | 12:40 PM
ls2 bait's Avatar
ok so there is some method behind the madness. just wondered why i had seen some that were shorter. mine are still stock length and my car is lowered quite a bit. everything i have suspension wise is gearded towards going in a straight line so i want to try and tighten it up a hair without loosing much if any in a straight line.
Old Jul 8, 2009 | 01:18 PM
99Bluz28's Avatar
If your car's geared towards straight line performance, why not just remove the whole front sway bar assembly, that would drop some decent weight.
Old Jul 8, 2009 | 09:25 PM
ls2 bait's Avatar
it is. but i want to get a little of the handling back. it rolls pretty good in the corners.
