Rear shocks fully extended?
For some reason my rear suspension does not seem to settle down and my qa1's are fully extended so I have no travel in the suspension. I have Qa1's all the way around with 300lb springs in front and the stock springs in the back. I have replaced everything in the rear suspension with adjustable BMR parts. Any ideas why it's fully extended?
The gap to the fenders is pretty big. On full soft the shocks will go down but there is no movement up from it's normal sitting position. Could my control arms be binding or something?
Put some jacks under it then loosen the LCA nuts/bolts, and PHB nuts/bolts , the remove the jacks and hopefully your car wil drop down then. If it drops down then re-tighten the nuts/bolts with the car on the ground or backed up on a good set of ramps.
Good luck!
