What hardware (sizes?) do i need for LCA brackets?
Hi all,
I just bought some LCA relocation brackets from a member and he didn't have the hardware. I was just wondering what size bolts I would need to use the brackets with the stock LCAs.
Obviously these are the bolt in style.
It appears that I'll need a ferrule too, that seems pretty important.
Thanks for any help, I'd hate to buy $40 in hardware to find the right one.
Hello
Do you happen to know who manufactured them? If so I would suggest giving them a call to make sure you get the right hardware and the correct sleeve for the brackets as well. If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Thanks
Brad
Thank you, after looking at pictures it appears to be UMI brackets. I got some grade 8 fasteners and i used galvanized pipe nipples as the spacers. It worked great and the brackets lined up no problem. I checked the fasteners after the first 5 times i drove it to make sure everything was bind free and not loosening.
Thanks for the help though, I appreciate it.
