rear suspension slowly sagging on C5 z06, help!
a friend of mine owns a C5 z06. im not sure if the suspension is stock or not....i believe it is not. anyways...the car 2 months ago had about 2 fingers width between the tire and rear fender. since then, it has slowly settled so far no that you cant even squeeze a finer between the tire and fender, its freakin slammed. rides really rough and it constantly hitting the bumpstops. what all could this possibly be? both sides are sagging the same amount, so its not a spring/shock issue.
Luckily the ride height is something that CAN be adjusted easily on those cars.
The ride height adjustments are made with the bolts, and while one of the adjusting nuts could have worked itself loose, I doubt that both of them would loosen at the same time, allowing both sides of the car to drop equally. To me, it sounds like the spring has gone bad
LS1TECH Sponsor
Why can't it be a spring issue? Corvettes use one spring in front, one in back, transverse leaf springs. It it's yielding an end of the car will sag, not one corner like an spring that is only responsible for one corner of the car.
__________________
