Alignment Specs for DD/AutoX
The car is lowered 1.2" and I'm looking for a good set of specs for a daily driven car that will hopefully see some AutoX.
From research I'm looking at doing:
Camber: -.75
Caster: +5.0
Toe: +1/16 (toe in)
How does this sound? Please Comment
Thanks
Edit: Im running 245's in the front and 285's in the rear, Sumitomo HTR-ZIII. Cheap tires so dont mind a little extra wear.
caster looks fine if you can even get there...some cars are caster challenged.
good luck.
I found that the car was quite prone to pulling and darting in ruts on the road (ie: on the main freeway from all the truck traffic) but it HANDLED incredibly well on-track, and I also ran 1 auto-x event like that
(took 3rd FTD, at my first event ever!) Camber: -1 L/R
Caster: +4.5 L/R
Toe: +1/32" (IN)
I do not auto-x, but I was doing a lot of hard canyon runs and some track days and worked out great..for better tire wear, probably take the camber down to ~ -.75 and maybe make toe +1/16" (IN)...I am assuming the auto-x courses are predominantly short/tite.
Ideally you would keep changing your alignment with each event and how the setup differs time to time. You want toe out (-) when a track/course has long/fast/sweeping corners. For shorter corners/tracks that have tighter corners you want to go with toe IN (+). Maybe even leave it as +1/32" like mine and go from there after you get the feel for how the car handles/behaves on that alignment..if anything just drop your front tires a pound on both sides and it's a decent temporary fix
I'm sure Sam can/will chime in soon
EDIT: I am running 275/40-17 Nitto NT-01s and carbotech pads on Strano springs, strano f/r sways, Koni 4/4, and some chromoly d/a rod ended LCAs...
2. 1/16th toe-in will help steering be more quick and tight, correct?
3. The more caster the better, right? max factory a-arms can go is 4.5? or 5.0?
3) again preference...but I think max is like 5 or 5.5
Toe in will reduces turn-in response yet increases straightline stability.
Toe out can help cure wandering associated with negative camber adjustments.
Toe in can help cure wandering associated with positive camber.
I used to run an oval track car, and we ran about 1/8" toe-out, IIRC, but I'd never run toe out on a street car.
