driving with no panhard bar?
Old 08-21-2009 | 08:40 PM
JustAnIlluzion's Avatar
Default driving with no panhard bar?
hi
my buddy took off the panhard bar bc of a big exhaust and now is driving around. I told him to get a relocation kit, but before it arrives, can he drive around withOUT the panhard bar? seems like a bad idea. stock 99 camaro btw
let me know
thanks
Old 08-21-2009 | 08:58 PM
mitchntx's Avatar
LOL ... the rear end will move side to side. Yes ... he needs a PHB ...
Old 08-21-2009 | 09:38 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Are you talking about the brace above the panhard rod, or the panhard rod itself? The panhard rod itself holds the rear end in place side-to-side, so yes, that bar is very necessary. The upper panhard brace gives the body side mount some rigidity, and while I wouldn't drive around for long without one, you'll probably be okay for a little while without the brace.
Old 08-21-2009 | 11:26 PM
mitchntx's Avatar
And the relocation kit doesn't relocate the upper bar.
Old 08-21-2009 | 11:41 PM
laux06's Avatar
the upper panhard is the ONLY part moved with the relo kit... half way down the page
http://www.bmrfabrication.com/F-bodySuspension.htm
Old 08-22-2009 | 01:54 AM
thanks, I told him but he is still driving around without it..
Old 08-22-2009 | 06:30 AM
SoxXpupPeT's Avatar
yeah hed need the panhard bar.. well if he F's it up then you could say "i told you so"
Old 08-22-2009 | 07:35 AM
mitchntx's Avatar
Ah ... I see what BMR calls a "relocation bracket".
I was referring to a relocation bracket from Unbalanced Engineering (http://www.unbalancedengineering.com/Camaro/).
One simply makes room and the other addresses a handling issue.
Old 08-22-2009 | 09:14 AM
MeentSS02's Avatar
Semantics - as you already said, what they call a relocation kit just gives you a little more room, but pushes the body side mount of the panhard rod down, leaving it not level anymore.
Old 08-22-2009 | 10:24 AM
z28bryan's Avatar
From the site:
Laser cut steel brackets that relocate the panhard rod to lower the rear roll center 4 inches and also level it for lowered cars. These brackets result in additional rear grip in all phases of cornering. They require a panhard rod that mounts via 1/2" bolts and and require a competant welder for installation.
I wonder if this would be good for a short circle track...
Old 08-22-2009 | 10:33 AM
Arctic2002ss's Avatar
Don't worry, the tires and inner fenders will keep the axle under the car.....
Old 08-23-2009 | 12:45 PM
leadfoot4's Avatar
Quick Reply: driving with no panhard bar?
