UMI rear suspension pkg or torque arm/drive shaft loop?
i'm coming up on some extra cash in a month or so and i want to either buy UMI's rear suspension package with the single adj phb and lca's or the adj torque arm with the drive shaft safety loop. which package would be better with my current set-up in my sig?
my plan is to build this car from the ground up, mostly stock right now. i'll eventually buy both, i'm just wondering which package would benefit me the most right now? i'm leaning towards the torque arm pkg right now.
thanks for your inputs
Thanks for considering UMI Performance! The combo that you are talking about above is a really great set up! I have a few questions for you! And how often does the vehicle see the track? Is it a daily driver? What are the plans for the vehicle as far as HP wise? If you can get back to me with the info and I will be sure to help with any advice needed.
Thanks
Brad
right now i don't take it to the track. i'd rather spend my money upgrading than fixing broken rear ends, etc. eventually i will pop it's track cherry but not until i've finished the suspension and gotten a better rear end. i drive it probably two to three times a week at most now that i have a beater DD, lol.
right now my hp goals is in the ball park of 500 with room to grow down the road. i bought a couple of your parts before and was really impressed ad i like to stick to the same brand. the kyb shocks and eibach springs were a newbie mistake and will be replaced later on. thanks for your help.
Hello
You will be fine with the adjustable rear end package! And seeing how you are going to be using a TSP Set up I would suggest going with a full length torque arm (part # 2205) due to clearance issues. And depending on what transmission you have I would suggest going with torque arm relocation cross member. To eliminate any issue of possibly breaking the tail shaft. If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
uncatted, but i've run into another issue so i probably will be spending the cash on different parts. thanks for all the info, i'll have to buy these parts at a later date.
