Holy Squeaky LCA's!
Old 11-28-2003, 11:57 AM
Goodrich's Avatar
Default Holy Squeaky LCA's!
I finally got around to putting on my G2 LCA's I ordered over a month ago when they had the suspension sale. I gotta say, they eliminated about 90% of the wheel hop I used to have and help the car plant the rears really well. However, they are squeaky as hell! I greased em good too, but everytime I hit a little divet in the road or go over a speedbump they squeak so loud you'd think the frame was twisting. I figured a little squeaking was normal but does anyone else have this issue? Is there somethng I can do to make them less squeaky? Different grease?...
Old 11-28-2003, 02:01 PM
K9Kev's Avatar
We had ours installed on our police Camaro right at Lou's shop. They greased them, set them and everything...but they squeek as well.
I am EXTREMELY IMPRESSED with the way they make the car plant, handle, etc, and I have kinda gotten used to the sounds.
I prefer to think of it as one of those things that happens when you get rid of weak factory parts and upgrade to serious performance parts. Kinda like, No pain, No gain...
I'm sure that they are fine, but give Lou a call and check if you are still worried. He is super easy to talk with and a wealth of info.
Kev
Old 11-28-2003, 06:16 PM
Dom
Dom's Avatar
Mine haven't squeeked or make a noise in the year and a half I had them. I've been driving it in Chicago weather and the rods are starting to rust. And they still don't squeek. I never regreased mine either. Are you guys using water proof graphice grease?
BTW, I might have to eventually replace those rods due to rust. Where can I get some of the same exact rods along with those rubber boots?
Old 11-28-2003, 08:31 PM
Cheatin' Chad's Avatar
LG sells replacement ends as well.
Old 11-28-2003, 08:33 PM
yagrmiestr's Avatar
hmm... my stock ones have always squeeked a little over speed bumps.
What kind of LCAs are you guys using? (Poly/Poly, Poly/Rod, Rod/Rod)
Old 11-28-2003, 08:56 PM
Dom
Dom's Avatar
poly/rod
Old 12-04-2003, 01:59 PM
Goodrich's Avatar
Here is a link to the LCA's on G2:
http://www.lgmotorsports.com/OCLS1_Fbody_Suspension.htm
Old 12-04-2003, 02:14 PM
mitchntx's Avatar
After 2 years and the cooler weather, mine have begun squeaking a little.
I need to take them down and clean and relube them. I use a spray on graphite.
Old 12-04-2003, 03:16 PM
Moderator
jimmyblue's Avatar
If they are poly/poly and have less compliant bushings
than stock, they may in fact be making something else
take up the flex, something that wasn't used to moving
and hasn't been lubed?
Old 12-04-2003, 04:44 PM
LSX Mechanic
Damian's Avatar
Grease them ALL OVER. Do not use the grease fitting, it doesn't do ****. Get some good grease, put it on your finger, and rub it all over and inside each end of the LCA's. Make sure there is a little grease on the sides of the LCA mount as well. This will take care of your problem.
When I first installed my LCA's 3 1/2 yrs ago, I didn't grease them and they squeeked so loud you could hear it from across the street if I went over a speed bump.
Josh
Old 12-09-2003, 09:42 AM
Goodrich's Avatar
I put the grease all over the LCA ends but I didnt grease the mounts. I was just over at Jiffy Lube getting an oil change and I had them blast the fittings but it didnt help. When I get springs (hopefully for Christmas) I will be putting the relo-brackets on and will try re-greasing them or try that graphite spray idea.
Quick Reply: Holy Squeaky LCA's!
