line lock
Our SJM kits are available in many configurations. They all come complete with preformed lines, a master switch, control switch, remote mount LED and all associated wiring needs. Unbolt the stock line and replace our lines with solenoid. Ours come with all fittings preassembled. Teflon sealant is not needed either.
You can view them in the braking section of our website www.sjmmanufacturing.com. Full directions are included as well as customer support.
The top mount is super-easy to install...but some do not want others to see the solenoid...the choice is up to each person as to which way they feel more comfortable.
BTW.. why does this Line lock cut my tire life by about 80% ???
The shifter switch, that picture is actually on the website. If you look to the right side of the drop-down box, there is a question mark. Click it. That will bring up the picture of the switch mounted on a stick.
Here's a front mount location kit using our solenoids.
Our top mount kit locates the solenoid on the top of the fender-well right above the one pictured (right next to the bolt sticking out). Same mounting position for the Hurst-style kits. With the Hurst configurations, we do not offer a front mount kit.
All style kits are in stock and can be shipped within 24 business hours (usually same day if ordered by 1pm EST), so that shouldn't be a deciding factor either.
Thanks
Just ordered a top mount one from your site.
I kid. I have SJM's and have no regrets.
