sjm abs delete/line lock help with the prop valve
anyone know the easiest but yet accurate way to adjust the wilwood prop valve in this kit, im on big and little tires also, ive gona both ways and it doesnt seem to make much difference s.o.t.p.. only thing i noticed is my rear brakes now screech when pressed..
Give me a call on Monday, I'd be happy to help you with your questions. In a nutshell, the idea of the valve is to adjust brake bias insomuch as you're less likely to lock one set of brakes before the other.
