Koni on Lower perch affect on handling and ride?
How would lowering my konis to the lower perch affect ride and handling? Car also has strano springs, sways and watts.
LS1TECH Sponsor
I don't recommend the lower perch in conjunction with lowering springs. Can't stop you if you want to do it, but you are left with very little working travel. As such the ride will firm up a good deal. It's a free country, the only time I'm ok with it is on cars that sit high in the front (say had a good bit of weight removed).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
