bleeding brakes?
Sorry if this is a dumb question (I feel like it is) but I am at a loss. Everything is installed correctly and the master cylinder is full.
Edit: Nevermind, just found the Application Guide on their site.
If you have traction control and air gets in it or the ABS, you will need a Tech 2 to cycle the ABS motors to get all the air out.
If you get a price from a dealership and you don`t mind , could you post up what they are charging, just curious.
PER SERVICE manual with ABS/TCS bleed the left rear /front right then right rear/front left. Now I could have the order left/right messed up as it was over a year ago.
If you still need it PM me and I will send you that page out of the manual.
I put those speed bleeder bleed valves with check valves. I then took some clear tycon (plastic tubing and ran it up first then down into the bottle. This keeps fluid at the bleeder so if the hose sucks a little it pulls in fluid iinstead of air. Mine pumped right up and I got the air out pretty fast. I was surprised as I've had fits in the past getting all the air out. I bleed them by myself.
The reason to do it yourself and not at the dealer is you can put a good quality brake fluid like Strano sells.
ed
