Which torque arm is better???
Below I posted some updated pictures to help better explain our quality and material choices. Hope this helps!
It could help, but I can't and won't stand here and say it'll be a miracle cure in your case. Stock TA's flex, and that flex doens't allow the tires to be planted as hard into the ground. But that usually manifests itself in wheelhop. Not always, but usually.
If you get an adjustable TA and put some negative pinion angle in it, that can help plant the tires to. But 19's have little sidewall, and are probably never going to "hook" all that well anyway--but ever bit matters when you are lacking traction.
How come you changed the design of the torque arm where it goes into the bushing? Did you argue with BMR about that? Looks like you went with their design? I have the old crimped looking end that I just installed. Is mine going to fail?
Hope that helps,
Ryan
I know with 19s, traction is a joke, but if I can reduce wheelhop, that's a good thing for a stock 10-bolt. Thanks for the advice Sam. When I get one, you'll be who I call.
