Brakes/What Else?
Very good deal I must say!
Anyways, want to make sure I get everything I need to tackle this project one of these weekends.
I believe when I had my brake system flushed last year, they used DOT4, so I suppose I'll stick with that. How much do I need to purchase?
I have never bled brakes before, I know the rule to start farthest away and work up to closest from Master Cylinder. Should I replace the stock ones with the Earl speed bleeders? http://www.lmperformance.com/573/1.html
If so, before I start taking off everything, can I just unscrew the originals and thred the new ones in?
Also, I could possibly be doing the the installation myself, what would you recommend I use to bleed the brakes, like a hand pump style one? Think I saw one on autzone's site for approx $58.
Anything I am forgetting?
Thanks in advance.
As far as installing the speed bleeders, do it right after you clean(Brake cleaner)off all the dirt around the factory bleeder.
Does it matter if I use Dot3 or 4? I want to say it has 4 in it now but not certain. And if I have help, just need someone to pump the brakes as I bleed each one right? (dumb question coming up) does the car have to be on?
Not sure if I will have help to tackle it yet, so figured I'd ask now.
Thanks for the replies. I was just getting a little bothered by it, as other threads that weren't as specific as mine were getting answers. LOL
After searching several times came across that. Sticky worthy IMO.
Really want to get one of these 2 sets of brakes on next weekend before I head out of town for work for atleast a week again.
Though I have to admit, once seeing them in the packaging, they do see rather cheap, especially the spring.
But I'll give them a go.
autozone even sells a cheap One man bleeder for like $7. basically a small bottle with a clear hose attatched. put the clear hose on the bleeder open the bleeder. pump the brakes a few times and all the air gets out. close the bleeder remove the hose and your done. I used that yesterday by myself and it worked good.
I got to remember to buy some grease when I go to buy the fluid too. Isn't there a pin I have to put the hi-temp grease on? Sorry, only done one brake job in my life, and want to make sure its right on the bird.
get high-temp brake grease/lube from a parts store, and lube each slide pin well.
every lowes or home depot will have the tubing. less then a dollar a foot, also sold by the roll of 2-3 ft or so, for a few dollars. using DOT4 is fine. make sure it says "compatible with all DOT3 fluids."
if you do have someone pump the pedal, you do know you dont actually 'pump' while the screw is open, right? only floored and kept down while the screw is open, then closed, then off the pedal.
