Z06 calipers...
Old Dec 14, 2003 | 12:30 PM
Jabroni's Avatar
Question Z06 calipers...
Will the red Z06 calipers bolt right up to a 2000 SS without required modification or does something need to be done before they'll fit? Thanks.
Old Dec 14, 2003 | 01:09 PM
Scalpel's Avatar
They'll bolt right into the F-body caliper baskets. Just need C5 brake pads now
Old Dec 15, 2003 | 12:05 PM
Xsta Z 28's Avatar
You DO NOT need C5 pads . . . Only need the C5 pad if your are using the C5 basket and rotor.
The calipers are a direct swap.
Old Dec 15, 2003 | 12:08 PM
Scalpel's Avatar
Sweet, thanks for the info on the pads. That's great.
Old Dec 15, 2003 | 01:28 PM
slow's Avatar
direct swap, or do you still need to grind off 1 fin... i know it is simple to do, just wondering if it is still needed, as last time i looked into this, it was.
Ryan
Old Dec 15, 2003 | 01:51 PM
Xsta Z 28's Avatar
Ryan
Grind off a fin?
Never heard of it, and can't even imagine "where" a fin would be in the way.
Old Dec 15, 2003 | 03:49 PM
mitchntx's Avatar
About 1/4" of 1 fin or rib on the back side of the caliper had to be ground away to get the caliper to fit with relocation brackets.
Old Dec 15, 2003 | 04:36 PM
Nine Ball's Avatar
LS1Tech Co-Founder
The fin only needs to be ground if you are swapping over the entire Corvette brake setup, with the larger disk diameter and vette baskets/pads. If you are just swapping the calipers out, they are a direct bolt on if you keep the factory f-body baskets and pads. I have the red Z06 calipers on my '02 SS.
Tony
Old Dec 16, 2003 | 03:44 AM
Jabroni's Avatar
Thanks, y'all!
