ABS Delete?
Old Dec 26, 2009 | 09:54 PM
InfernoTA's Avatar
Default ABS Delete?
I would like to delete my ABS.Is there more than one way,If so which is the best?Thanks
Old Dec 26, 2009 | 09:56 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
SLP has a kit to do it.....
Old Dec 26, 2009 | 10:04 PM
InfernoTA's Avatar
Thanks I'll check it out
Old Dec 26, 2009 | 10:13 PM
LadyDriven's Avatar
Just searched their site for it, could only find the line lock kit they sell
Old Dec 26, 2009 | 10:42 PM
00T/AWS6's Avatar
SJM has an ABS delete kit, i just ordered it along with their linelock. i wont be able to get it in for awhile so won't be able to let you know haha.
Old Dec 26, 2009 | 10:45 PM
schram1124's Avatar
i have the same kit very nice kit to cold to install it im also going with bmr's man master to get rid of the boster
http://www.sjmmanufacturing.com/cam_brk_lt1.html
Old Dec 26, 2009 | 11:21 PM
01wssick's Avatar
advantages to deleting it? is their any besides weight reduction?
Old Dec 27, 2009 | 10:59 PM
InfernoTA's Avatar
I am looking to get rid of to clean up my engine bay.Looks much better without it.
Old Dec 27, 2009 | 11:12 PM
DemonInside's Avatar
does anyone know by chance the size of the fittings that screw into the master?
Old Dec 28, 2009 | 12:09 AM
02CamaroSSLE's Avatar
if mine was a track car only i would do it, but you never know when your going to need it on the road... but i do agree it looks very fugly!
edit check the appearence and detailing section im sure there will be a write up there, atleast to re locate it...
Old Dec 28, 2009 | 01:06 AM
00T/AWS6's Avatar
mostly it's just to save weight and clear room in the engine bay. I am doing mine because my friend has a 4 chan rear i'm going to buy but i have a 3 chan so just delete it and good to go haha. ABS is overrated anyway, i prefer driving without it. Only time it's been used or engaged has been in snow anyway which i dont drive it in.
Old Dec 29, 2009 | 09:06 PM
hiltsy855's Avatar
I just re-used the existing tube nuts but I'm sure they have metric threads for metric tube. The forward port in the MC is for the rear brakes and I re-made the line using 1/4" tubing (had to drill out the tube nut slightly). The rear port is for the front brakes and takes a 3/16" tube w/o modification.
Old Dec 29, 2009 | 10:28 PM
SJMMFGINC's Avatar
Ton of advantages for removing ABS, here's a few I can rattle off:
1) weight
2) appearance
3) no longer handicapped by having to use same diameter front/rear tires
4) increase engine bay air flow
5) more room for supercharger/turbo or custom cold air intake kit
6) less costly repairs for ABS system from failures
7) using an adjustable proportioning valve, you are able to tune the brake bias
8) easier to work on engine
9) easier to troubleshoot braking system
10) Simplified brake bleeding proceedure.
Kits are the easiest to consider as they are pre-made and pre-assembled. If one likes bragging rights to create their own custom setup, its not a time or really a cost savings mod. There's quite a bit of components needed...just the valve alone is ~45.00 plus shipping. I can try to help anyone if they prefer to create a custom setup.
Old Dec 29, 2009 | 10:36 PM
2001CamaroGuy's Avatar
1) weight
2) appearance
add to that list:
- better brake modulation
- smoother/positive feel
- more responsive
The ABS unit, due to the little valves/pumps/etc inside it, adds kind of a "blah" feel as these have an amount of give. Its comparable to rubber vs. steel braided hoses.
I personally did my own setup. The only parts "needed" are a T fitting and some brake line. You put the T in the front (to split left and right), then bend up 2 new lines to connect from the master to the factory hard lines. Cost me perhaps $10 and a few hours of work.
Old Dec 30, 2009 | 01:14 AM
SJMMFGINC's Avatar
2001camaroguy,
That was only a shortlist...lol there’s more that we could probably both think of. A bit of constructive criticism (or reading for others to consider). Your setup should have included an adjustable proportioning valve. That should bring your setup up to ~65.00 +tax or shipping (if you only had 10.00 initially invested, I'm not sure how for that little as brake tubing alone will be ~20.00 but I'll take your word for it).
Normally, the ABS system controls braking needs to an extent on the fly. As of right now, your braking system is not biased correctly and you're not taking full advantage of your brakes which will lead to longer more uncontrolled stopping.
It's actually quite a bit more complicated than a few t's. I think its great when folks design their own configurations as it’s nice to have bragging rights at a show or the track. I suppose in the end you may save 10-20 bucks over a kit...probably not if you include the time and gas it takes.
It's sort of like making your own lower control arms, you may save a few dollars but in the end is it worth it. I'd say yes only if you like to have as mentioned bragging rights.
You need a tube bender, flaring tools (two types) and quite a bit more to get it to the install point. Aside from the all the fittings needed (as mentioned the proportioning valve too)...brake line alone will cost ~20.00 unless you happen to bend and flare the tubing perfect the first time or don't care about how it looks.
hiltsy855 wanted a custom configuration which I helped him with the parts. I think his turned out rather nicely.
Old Dec 30, 2009 | 01:21 AM
01wssick's Avatar
wow, that answers my questions. i'll be sure to buy a kit. how long should an install take? hoping it's a little easier considering i have my engine/tranny out and can climb in there and work
Old Dec 30, 2009 | 01:32 AM
SJMMFGINC's Avatar
Kits are pretty fast to install. The most time consuming part would probably be bleeding the brakes or running the electrical line into the interior.
Old Dec 30, 2009 | 01:39 AM
01wssick's Avatar
can you give me some kind of install manual to look at?
Old Dec 30, 2009 | 06:04 AM
mook99ta's Avatar
Would you do this on a car that is a DD and occansional AutoX?
Old Dec 30, 2009 | 10:19 PM
cals400ex's Avatar
why can't you run different diameter tires with abs? i know the abs light comes on but don't the brakes function as they normally would?
