Lowerrr IT!!!!
Old Dec 27, 2009 | 11:59 PM
19BLACKBIRD99's Avatar
Default Lowerrr IT!!!!
I wanna lower my car a little, but not so much that it messes with my 11 inch back tires lol Wanna know what kind of springs I should get. I wanna notice that its low but as I said not to interfere with my back tires
Old Dec 28, 2009 | 07:01 AM
teke184's Avatar
koni SA
lower perch in front, heater hose mod in rear
should drop the whole thing 1/2" or so
i had to clearance the inner fender with my ZR1s/315s when i put my BMR 1.25" springs on.
Old Dec 28, 2009 | 07:27 AM
a97transam's Avatar
If you do the heater hose mod do you need an adjustable PHB? or is the amount lowered not enough to need it?
Old Dec 28, 2009 | 08:10 PM
So with those lowering springs, your tires still fit?
Old Dec 28, 2009 | 08:32 PM
MJs1FastSS's Avatar
on my 98 i had sportlines with zr1s with 11 wide in the rear with no issues.
dropped car a good amount
how much are you trying to go?
Old Dec 28, 2009 | 08:35 PM
I'm not trying to be a low rider, but I would like to try to fill the gaps in the fender wells and try to make the rims "stick out more as of appearance" lol
Old Dec 28, 2009 | 08:48 PM
bobbyd's Avatar
get some stranos.
this was my car with stranos and 11s in the rear
Old Dec 28, 2009 | 09:52 PM
ssam98's Avatar
Get some slp springs they drop the car 1/2 to 3/4 inch, and the ride is nice.
Old Dec 28, 2009 | 10:07 PM
CranMaro99's Avatar
No he should get Strano springs
Old Dec 28, 2009 | 10:19 PM
ill prolly go with the strano lol
Old Dec 28, 2009 | 10:24 PM
Bad_Karma's Avatar
Originally Posted by bobbyd
get some stranos.
that bitch is sexy.
that looks lower than my eibach pros.
and i am guessing they ride better too
Old Dec 28, 2009 | 10:27 PM
How hard was the install?
Old Dec 28, 2009 | 10:47 PM
bobbyd's Avatar
Originally Posted by Bad_Karma
that bitch is sexy.
thanks man it was sexy but it was totalled back in may
Old Dec 28, 2009 | 10:49 PM
bobbyd's Avatar
real easy man. the rears are the easiest for the front you will need a strut compressor to get the struts removed from the stock shock/spring.
theres a few videos here on ls1tech where they show you how to do it
Old Dec 28, 2009 | 10:57 PM
therealcreeper's Avatar
do you have shocks capable of handling the increased spring rates? are you willing to buy a panhard bar to recenter the rear, relocation brackets to correct geometry if necessary, and pay for an alignment?
just some other things to consider, since springs effect more than appearance
Old Dec 29, 2009 | 06:32 AM
teke184's Avatar
i'd never done spring/shocks in my life.
took me about 6hrs including over an hour to remove one nut on top of one of the front units. also had to go back and redo one of the fronts due to a forgotten washer.
really isn't hard...just a bit time consuming
Old Jan 8, 2010 | 01:59 PM
haha, I dunno I will try and do it fast like I always do, but I wanna take my time also, because suspension isn't nothing that need to be fucked up.
